Set up is malossi ported barrel and matched case transfers , 16' ignition , 1.25 mm squish, jl pipe and standard carb.
It pings its head off at about 6000 rpm, so mid throttle in 4 th.
I've tried with 140 air corrector and be4 in carb as been advised but tbh the 140 makes it 4 stroke.
Any ideas of how to stop pinging would be appreciated
Malossi 210 pinging in mid range
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
What's the full spec of your jetting?
Pilot, main, atomiser, air corrector etc?
The malossi kit is purchased from sip its the sesc tuned black coated barrel that comes with the mmw head that they claim reduces pinging !
The jetting for the 24 mm standard carb is pj 45/120 (2.66) mix screw 3 out, emulsion tube is be4,air corrector 160( tried 140 but 4 stroked) mj 132, slide is standard.
I use 95 octane unleaded.
Any suggestions?
Any suggestions?
- rapido230
- Main scooter: vespa 210 & lambretta gp
That kit is for a long stroke crank, I gather you have a 60mm crank? And I wouldn't run on 95 unleaded, I been using super on mine for yrs , on way cleethorpes I had to put in normal unleaded and it pinged and blew my piston
- drunkmunkey6969
- Moderator
Try this: 50/100 132m/BE3/140ac screw 2.5 turns out.
Thanks for the advice, I will try this set up. Yes it has a 60 mm crank.
If your set up was pinging on super rapido 230 wouldn't mean you have a similar problem. If so what was similar to my set that may identify the issue.
Drunk monkey have you experienced this issue and if so was it resolved by using a lower octane fuel ?
Sorry I got wrong end of the stick.rapido230 wrote:Meant mine was pinging on normal 95 unleaded, I ALWAYS use super but as no stations had super I was fooked lol, therefore an expensive repair
However I was under the impression from reading comments from well known tuners that the 98 Ron fuel contained additives for cars that increased detonation likelyhood in 2 strokes ?
Norrie Bodge
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
bogs wrote:Set up is malossi ported barrel and matched case transfers , 16' ignition , 1.25 mm squish, jl pipe and standard carb.
read here may help -> http://scooterotica.org/forum/viewtopic ... 40#p199440
& listen to the video in post #1 helps you understand how the emulsifier/atomiser works
