oops gp 205 gone pop
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Just leaving work. Bang and a bit misfire then dead. No compression at kicksart.
Ooops holed piston ???? :(
Should of took the running in more serious :)
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
Timbo
...lets hope your barell and crank are ok.
Boothy_the_makem wrote: Should of took the running in more serious :)
It's not the 'running In' (or lack of) which causes holed pistons......mostly it's lean jetting.
Boothy_the_makem
I posted a reply earlier but it hasnt registered ( shitte phone)
Anyway thanks for that monkey. I thought maybe my over exuberance with the throttle early on and maybe poor bedding in had led to friction and overheating.
I think the jetting is high if anything . I've kept it as is from when I bought it and resisted the temptation to lean the jetting :)
Its a ball ache but im looking on the positive. It gives me chance to strip some of the scoot. Check it over. Get someone experienced to check it lol .
Sort some things I werent happy with but most important find out why it did what it did.
Ive started stripping it today :)
Boothy_the_makem
Only two months since I took the exhaust etc off lol :)
So yesterday I strpped barrel and head off.
Piston is mint. Rings are fine. No damage to bore.
Conrod and crank fine...
So Im sitting on the shitter typing this today and thought I would just check the flywheel before I post.
Yep its sheared the rivets :D
mick1
Main scooter: Li Avanti 225
How does the flywheel rivets going explain the lack of compression ? am i missing something :oops:
Boothy_the_makem
mick1 wrote:How does the flywheel rivets going explain the lack of compression ? am i missing something :oops:
Well obviously there was compression I just assumed there wasn't as there was significantly less resistance kicking it over lol :oops: :mrgreen:
Anyways as yer can imagine am over the moon the piston an crank etc are ok hahaha :)
That's taking multi tasking to a whole new level. :lol:
Boothy_the_makem
Thats nowt mate.
One time I was on the crapper. Typing on me phone AND smokin a tab :) :mrgreen:
The problem came when I went ter put the tab down the crapper and burnt me cock :mrgreen: :shock:
Morgan
Main scooter: T5 Vespa Mk1
Thats nowt mate.
No ash-tray provided.......might be worth a claim :lol:
