400x10s
ducksta
can i fit 400x10s on a vespa t5 front and back (tuned engine) will it pull or bog down have i the clearance
on the back it will prob foul the engine arm if not the clutch cover ,and even if it looks like it clears by a couple of mill when trying to fit it up bear in mind tyre growth due to centrifugal forces lol. I could be wrong but i think it would poss up gear by approx 10% overall ,.also it may no longer clear your exhaust .
on the front is also not good ,as it will make the steering feel heavier and also may catch on the fork leg ,not to mention that it will throw out your speedo readings
,but by all means try it if you like and let us know how it pans out for you :)
ducksta
how about just on the back would that still throw the speedo out
mick1
Main scooter: Li Avanti 225
Think you can do the rear (oh err !!) using Cosa rims.....
ducksta
surley that will chuck the alignment out
mick1
Not enough to worry about...
ducksta
might make me go around corners a bit better does anybody make stabalisers lol
dont confuse the use of a wider tyre with one of greater diameter
soulboy
i done it with cosa rims for the back just used good washers as spacers :roll:
heavy front tire will cause over steer
