just a quick query
when fitting a cylinder head with an o'ring type seal, do you still put the copper gasket on the malossi 210 or do you do without it
cheers
sip cylinder head for malossi
If you take 1mm of the cylinder head then you can run without head gasket ! Check you squish is correct
