sip cylinder head for malossi
MCH
Main scooter: street racer px
just a quick query
when fitting a cylinder head with an o'ring type seal, do you still put the copper gasket on the malossi 210 or do you do without it
cheers
cgt75b
Main scooter: lambretta
If you take 1mm of the cylinder head then you can run without head gasket ! Check you squish is correct :D
