Hydraulic disc
I recently acquired this old Taffspeed hydraulic conversion backplate and slave. It screws in nicely by hand but stops hard at this point.
There's more thread inside the hole and I kind of feel it should go all the way home.
As both parts are alloy I'm very reluctant try to force it in further.
can anyone confirm if it should go in further than this?
gaz_powell
Ross
Not sure who did mine (it came with the bike) but it bolts up flush
I would be thinking the same as you about it been flush but might be worth a pm to Ian F there might be good reason.
Gaz
Cheers Gaz, will do.
Not heard anything back, but after a couple of hours diddling with a 1.5 pitch tap and some emery paper I managed to get it screwed all the way home, which is lot more encouraging.
Terrible Taff
Main scooter: Lambretta's & Vespa's
Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
rosscla wrote:I recently acquired this old Taffspeed hydraulic conversion backplate and slave. It screws in nicely by hand but stops hard at this point.
Hi Rosscla
Yes it is supposed to fit flush & with the M7 bleed nipple exiting rearward from the slave unit.
Cleaning up the threads will help.
The seals & piston unit is 36mm Dia from a 4 pot BLMC Mini Metro brake calliper.
I hope this has helped you.
Ian T Frankland
Taffspeed Design Innovations
Mob: 07971 818693
Email: [email protected]
rosscla wrote: a couple of hours diddling with a 1.5 pitch tap .
get your self a thread file .. saved me a lot of work in the past
@ Ian, many thanks for the confirmation. I'm out of the country right now but if I remember correctly now it's screwed right home and the bleed nipple faces to the rear, albeit at the bottom rather than the top which is kind of where I expected.
@ RIC - I have a thread file but buggered up the 1.5 pitch trying to sort a layshaft thread, layshaft harder than file :-/...can you recommend a good one?
mine has no mark on it so cant say ..been ok for me
If anyone else interested in this I sourced a seal repair kit and piston from minispares.com
Part numbers -
Piston - SAAS1022
Seal kit - GRK5003
£21 inc VAT and P&P
Now, does anyone know where I can get a long bleed nipple for it?
A standard one doesn't bottom out before the thread runs out so won't seal. Suggestions?
warts
Main scooter: honda
70's and early 80's big Guzzi's had 6mm fine bleed nipples in their Brembo calipers. They were also available in stainless into the 90's at least, probably still are on specialist sites. They are quite long.
http://www.motomeccaspares.com/products ... ategory=BS
Any use?
There is/was a grumpy old git up in the wilds near Bradford, who used to make them. A trawl in old bike mags may unearth him. Dave something.
There are a few German Guzzi sites that offer what is now more difficult to come by Brembo stuff.
