jockey boxenstop rear brake
DigDug
I don't see a preview - I see the big picture?
Did you have to do that?
If you post a reply using the full editor you can see the thread below the editor and there I see the full pic, but not is I just view the thread.
Screenshots -
twenty eight
roadrunnerian wrote:hi had one fitted used now for 300 miles and it will still not stop as good as before fitting it. no matter how much pressure, adjusting the cable,even roughen the shoes up still will not stop like it should, is it better to fit standard shoes any ideas?
I fitted one locks the back wheel up first time this has happened since owning the scooter,have you checked to see if the allen bolt that holds the cam tight has come loose and moved causeing your shoes not to expand
Terrible Taff
Main scooter: Lambretta's & Vespa's
Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
Having set up the cam & set the brake shoes correctly they will work ok. The shoes are 150mm x 25mm wide & the Lambretta drum unit 152mm dia so will take a while to bed in fully.
There are also various makes of brake shoes available besides the Lucas brand that are supplied by "Jockey Boxenstop"
Some more expensive - EBC Y510, NewFren GF1167, Vesrah VB228 if you wish to try other brake shoe compounds!
Ian T Frankland
Taffspeed Design Innovations
Mob: 07971 818693
Email: [email protected]
roadrunnerian
thanks all for your replies, will get it stripped and looked at
Terrible Taff wrote:Having set up the cam & set the brake shoes correctly they will work ok. The shoes are 150mm x 25mm wide & the Lambretta drum unit 152mm dia so will take a while to bed in fully.
That's interesting to know that other shoes might be available for this kit. I was kind of wondering where I'd get replacements from if needed.
Strummer10
I realise sometime has passed since this thread was started, but are there any conclusions as to whether these shoes work correctly or not ?
roadrunnerian
mine work perfect now found that the outer brake was to long by 10mm they now lock up :D
dennis
Main scooter: 1 gp 1 special
Whats an outer brake?.
Presume he means 'cable'
    Users browsing this forum: Amazon [Bot] and 6 guests
