Wosner piston
Yanker
sydduckett wrote:the rings pegs were moved slightly on different years. Id have to look back at prev posts re this. I wanted to try and get it from AF but if they havent got anything to suit ill have to have a think about where to go from there....bugger... :?
yep, got caught-out in that one miself: top peg runs very close to the boost port edges.
http://www.lambretta-teile.de/Kolben-66 ... tta-RB20_1
Darrell Taylor
Main scooter: LAMBRETTA
you could post the cylinder to af and get them to check the clearance or ask if they dont mind you buying the largest for you to check then refunding if its too big on clearance
Spanish Fly
Main scooter: P200e
Ceramic coat the piston? :idea:
SF
sydduckett
I hope so, will be a right balls ache if i have to hunt down a piston nearer my bore.
sydduckett
Spanish Fly wrote:Ceramic coat the piston? :idea:
SF
can that be done? Wiseco are a good piston. Dont know if they will go with an rb?
sydduckett
Do you know if this is 66 dead? Thats a lot closer to my bore. Could be the go. Please dont tell me these ones have the potential peg position.... :cry:
sydduckett
thesx200 wrote:Why not re-peg the piston
To be honest id rather keep it as a spare as its a cheapo and put the best in i can afford. The 5 speeds been in its box since Wicksteed and the iv finished paving the drive so im back on the rebuild. Hoping for a wet one tomorrow so i can get a day in the garage......Is that wrong..... :o
Eibar
Main scooter: Eibar TS1 1966
"ahem "
We run a wiseco piston in our RB20 , worth ringing ben and seeing if he's got any to suit.
potato
Muppet
too many chiefs not enough indians ;)
C’est la vie
sydduckett
Eibar wrote:"ahem "
All well and good but is it the right side of 66....
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 34 guests
