Wosner piston
sydduckett
I need a new piston for my rb20 and was going to buy a Wosner one from AF along with an avanti Rb head. i had my barrel ceramic lined recently and have a 66.08 bore, the Wosner comes in a,b and c with the following corresponding sizes 65.94, 65.95 and 65.96. Am i right in thinking that there grade c which is nearest is to still to far away?
Ta
Sef
mick1
Main scooter: Li Avanti 225
A ball park figure for clearance is 4thou' (inches) which equates to .10mm
You would have .12mm ......in my personal opinion (I'm a sparky by trade ??) go for it...
Yanker
Yes it is still too far away! 0.06 max. Why the fuckinell did you not send the intended piston in with the barrel for the re-plate?
sydduckett
Yanker wrote:Yes it is still too far away! 0.06 max. Why the fuckinell did you not send the intended piston in with the barrel for the re-plate?
Needed to replace piston and get a replate so got hold of a blaster piston and had it matched when plated. Found out after that pegs are not in best place so got rid of that, hence need for new one.
Anyone got any suggestions for a piston that will suit? Will buzz AF on tuesday to see what they suggest. They still only answering after 5?
Ta
Muppet
what space is blaster pegs?
C’est la vie
sydduckett
the rings pegs were moved slightly on different years. Id have to look back at prev posts re this. I wanted to try and get it from AF but if they havent got anything to suit ill have to have a think about where to go from there....bugger... :?
mick1
Just checked again and .12 millimetres = 0.00472440945 inches.
maybe give AF a call but i thought that was within tolerance....maybe slightly high but still ok.
Muppet
4thou is often quoted for a ts but is it the rite number? i dun think tis!
C’est la vie
Eibar
Main scooter: Eibar TS1 1966
wiseco ?
potato
thesx200
Why not re-peg the piston
