Piston to bore clearance
soosh
Adam_Winstone wrote:^... not like your next ride was going to be a biggie though :shock: (Milan 97)
Thats what was doing my head in,2000ml trip planned and this thing was rattling like mad and was told its fine by them!! :shock:
Just meant after that rebore i had to get some miles on it quick before the off. Was good doing the rebuild in the kitchen,good old days when you could do that.That trip was absolutely fantastic!! :D
Adam_Winstone
Good times :)
a.j
I've suffered from heat seizures for feckin' years. My carb has been set up perfectly. Examples; on this b/h Monday I took a 25 mile motorway ride in glorious sunshine and warm weather and it ran like a dream.
Today I got on the motorway in colder temperatures and nipped up after four miles!
Work that one out! :-(
bristolmod
what piston is in there?
Scootering since 1968.
Grumpy225
a.j wrote:I've suffered from heat seizures for feckin' years. My carb has been set up perfectly. Examples; on this b/h Monday I took a 25 mile motorway ride in glorious sunshine and warm weather and it ran like a dream.
Cold air=dense air=more air=lean condition=sieze
For me, I like to jet a bike when it's around 70f, this way when the weather cools down or warms up the jetting won't be too far off from where I started and extreme changes in the weather can be handled by a mix adjustment on the carb.
soosh
That's a f@@ker then if you get a new carb for Christmas.
soosh wrote: That's a f@@ker then if you get yourself a new carb for Christmas.
Fixed ;)
nelson pk
Yep, cold air will cause a leaner condition. A road going scooter should be jetted with enough margin for error in my opinion. For example, it will run rich with slighty less performance on a hot day and run better on a cool day but not too lean. If you have and adjustable power jet and EGT or CHT you can adjust jetting easily to suit conditions for better performance.
a.j
Same conditions as yesterday, took it out for a few miles thrashing with fingers over the clutch & it ran really well. Doing me nut in!
    Users browsing this forum: Majestic-12 [Bot] and 15 guests
