while my GP was running up on the dyno it was noticed that the hub runs out, its got a wobble on it, and now having ridden it more I have noticed that with light application of the rear brake you can feel it pulse, like a warped disc does.
going to look into it further, take it off, double check its all clean etc, but Im sure it is. if it was a problem with the cone fitting then I would expect to see it move left to right when viewed from the rear, but its doesnt, just up and down when viewed from the side
so whats the options, I have read not to use RAMP? ones
Im guessing that any genuine innocenti ones by now could be as bad or worse than mine
whats the choices of rear hubs
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Toddy
- Main scooter: Lambretta Series 1
+1Doom Patrol wrote:http://www.scooterrestorations.com/lamb ... -cone-sil/
Genuine SIL ones are worth considering too.
+2Toddy wrote:+1Doom Patrol wrote:http://www.scooterrestorations.com/lamb ... -cone-sil/
gaz_powell
AF do a great deal on uni auto hubs in silver, black or white
- coaster
Before splashing out o a new hub make sure it isn't just that the rim isn't sitting flat. I had that problem after a mat followed be and noticed the wheel wobbling. Naturally assumed it was a bent hub so ordered a new one but when re-fitting the wheel I noticed that it wasn't fitting up properly due to thick paint. The original rim went on another engiune and is still running true.
