whats the choices of rear hubs
tonydevon
Main scooter: '71 GP125
while my GP was running up on the dyno it was noticed that the hub runs out, its got a wobble on it, and now having ridden it more I have noticed that with light application of the rear brake you can feel it pulse, like a warped disc does.
going to look into it further, take it off, double check its all clean etc, but Im sure it is. if it was a problem with the cone fitting then I would expect to see it move left to right when viewed from the rear, but its doesnt, just up and down when viewed from the side
so whats the options, I have read not to use RAMP? ones
Im guessing that any genuine innocenti ones by now could be as bad or worse than mine
rapido230
Main scooter: vespa 210 & lambretta gp
Hubs by Uni are good, mb sells them with decent studs and a cone too
weedodger
Main scooter: Indian gp casa 185 and 200
Yip , got a uni hub an cone and good studs also from mb,
tonydevon
thanks, off to browse MB website and warm up the bank card
http://www.scooterrestorations.com/lamb ... -cone-sil/
Genuine SIL ones are worth considering too.
tonydevon
oooh £20 cheaper, certainly worth a look
cheers
Doom Patrol wrote:http://www.scooterrestorations.com/lamb ... -cone-sil/
+1 :D
DaveTomo
Main scooter: SX 200
+1 :D
+2 :D
gaz_powell
AF do a great deal on uni auto hubs in silver, black or white
Before splashing out o a new hub make sure it isn't just that the rim isn't sitting flat. I had that problem after a mat followed be and noticed the wheel wobbling. Naturally assumed it was a bent hub so ordered a new one but when re-fitting the wheel I noticed that it wasn't fitting up properly due to thick paint. The original rim went on another engiune and is still running true.
    Users browsing this forum: Ahrefs [Bot], Google Adsense [Bot] and 7 guests
