Px200 polini exhaust
mongoose
Main scooter: px
Thinking of replacing my sito +, i have had a polini on a px125 before.
I know these are still available but there is a Mk2 version as well.
Does the mk2 exit right side also, is it any better peformance wise. It would be going on a stock engine.
gaz_powell
the mk 2 is SSC RH side exhaust
they used a similar design to the polini for the mk 1
http://www.saigonscootercentre.com/Prod ... =178&s_id=
the mk 2 is made up of more cones than the previous one - more in line with the jl/revolver style
http://www.ebay.co.uk/itm/Vespa-Polini- ... 423wt_1038
Looking at its construction it looks like it should work better than a polini/mk1 - and the SSC build quality will be good -they are cheaper than polini by about £30 - definately worth a punt if you after something new
I have x3 of their lambretta exhausts
I wouldn`t mind trying the mk2 on my P2
Shaunbond
I had one like in the 2nd link on my HB stage 4 PX200 for a short while, whilst 3rd gear was real fun it just couldn't pull enough uphill, into a head wind or both with my standard P2 4th gear so iwent back to sito+. Tempted by a Sip road though.
Serial scooter rider...
VMSC Committed to Scootering for 25 years
Bifter
Main scooter: vespa p210
Sip road will give better low down grunt
mongoose
Main scooter: px
That was one of the worries, it seems the newer version looks more suited to a tuned engine.
It was the sound and the cosmetic look that is appealing. Wanted to get away from the standard look.
gaz_powell
good first hand info from Shaun - you cant get better than that !
goldeneye
never tried the MK2, but looking for something to put on the HB200, its got a T5 4th gear in, and I'm quite svelte, (no laughing at the back) so will maybe pull 4th a bit better. at 110 quid, looks a canny punt.
H,POOL GADGE
Main scooter: vespa polini220/gts 300
the mk2 polini's very, jl, revolver, siminini likey like! obviously there's something about the length + size of expansion chamber that gives these exhausts a balance of torque and revs, which helps lower bhpowered tunes, I wonder what H Barlow does to a siminini when he opens them up? anybody know whats inside one? or what he does to them?...
goldeneye wrote:never tried the MK2, but looking for something to put on the HB200, its got a T5 4th gear in, and I'm quite svelte, (no laughing at the back) so will maybe pull 4th a bit better. at 110 quid, looks a canny punt.
They are a bit cheaper if you buy direct from the shop instead of eBay: http://www.scooterotica.net/userimages/procart11.htm £99.95 (second from bottom of page).
Richjak
I run Mk II polinis on both my Vespas which i got from Saigion Scooter Centre both are excellent quality - the main difference being for the 150 lump the exhaust is a one piece construction and increases the power significantly - i repacked the muffler when i got it chromed and since then it has been a bit on the loud side for me so i will get it redone, the noise is worth the additional torque and i love this set up, even though its a standard barrel.
The 200cc version is a 2 piece construction with the joint between the downpipe and exhaust body being spring loaded on this version the noise level is ok but the resulting performance on a standard 200 barrel wasnt as significant as with the 150 version i have had issues with the securing bracket that bolts to the crankcase break twice now - finally i made my own bracket from heavier guage steel and that seems to have done the trick.
Generally speaking they are both good exhausts for the money and look the part.
BOTAK ITU INDAH.
