Honda 205 gudoen pin
Lads need a bit of info/help here ....Have mislaid the gudeon pin for me 205 piston and an online shop is asking for a dia(16mm) and length of pin so as to supply a replacement sooo can anyone get me the measurement for the length of the pin ....Cheers
Cheers lads thanks
just checking the piston and the bloody rings are spinning and one of the pegs is very loose not having a good day .... will now be requiring another piston as the hole the peg is making would require a bloody weld rod to plug it ,,,,Grrrrrr
