Honda 205 gudoen pin
Lam-d
Main scooter: 71 Gp200e
Lads need a bit of info/help here ....Have mislaid the gudeon pin for me 205 piston and an online shop is asking for a dia(16mm) and length of pin so as to supply a replacement sooo can anyone get me the measurement for the length of the pin ....Cheers
The one I have is 1st oversize and the pin is 56mm x 16mm
Muppet
wack 63 wrote:The one I have is 1st oversize and the pin is 56mm x 16mm
tis same 56mm lenth on 67mm standerd honda mtx pistn
C’est la vie
Lam-d
Cheers lads thanks
Lam-d
just checking the piston and the bloody rings are spinning and one of the pegs is very loose not having a good day .... will now be requiring another piston as the hole the peg is making would require a bloody weld rod to plug it ,,,,Grrrrrr
