Reflections in Blue the RB22 Rev 2 update
RinB
drunkmunkey6969 wrote:
RinB wrote:I need to run it and see how she goes before Dyno m8
Not even a gentle mid range run through gears 1-4 to check torque and A/F?? ;)
Tempted but If I got it there, I know Id be up to going the full monty :lol:
Plus Im doing Donny Hunters LCGB run on Sat, so will see really how she performs then
good try dan.........he,s obviously very confident that he has set it up to perfection .......OR ......is just suspicious .........and thinks that while i distract him to make him a cuppa......and talk about the intricases of inlet port tuned length ...you will strip it down and discover /steal away all his tuning secrets........... :lol:
RinB
sean brady scooters wrote:good try dan.........he,s obviously very confident that he has set it up to perfection .......OR ......is just suspicious .........and thinks that while i distract him to make him a cuppa......and talk about the intricases of inlet port tuned length ...you will strip it down and discover /steal away all his tuning secrets........... :lol:
:lol: :lol: :lol:
No just scared that with that distraction of a cuppa it'll be ragged like f@ck on the dyno before I can get some miles on her :lol:
would we do that mate..................... :lol:
RinB wrote: No just scared that with that distraction of a cuppa it'll be ragged like f@ck on the dyno before I can get some miles on her :lol:
Just sort your piston clearance and ring gaps........rev to 10,000 rpm on a long straight and you're done. ;)
were only joking smiffy.........
you would be ,i,m sure perfectly welcome to running it on the dyno yourself......................
RinB
Oh forgot to say Ive put a Foxhat 6 plate clutch in.
Its nice and so positive feels good to me :D :D
RinB
sean brady scooters wrote:were only joking smiffy.........
Sure m8 Ill see about coming across some time
But once she run in :D :D
is that the first FOXHAT that you have used then...........?
RinB
sean brady scooters wrote:is that the first FOXHAT that you have used then...........?
Yep had a choice try Cam lam red 6 plate system but we went that way on Mab's RB 250 so I went for Foxhat
to see the differance and longedity of the two systems.
Those Cam Lam Red plate an't half thin but there meant to be good ,so we'll see Hey
