PX rear hub conversion
- djh66
- Main scooter: 150 special
I'm in the process of coverting a px engine to 8" rear hub to put in mates Sportique, using SIP's conversion kit http://www.sip-scootershop.com/en/main/ ... r=50015160 however I can't get the hub on, over the supplied brake shoes! Any ideas?
Bring Me Sunshine COYH
- djh66
Were/ are there different rear brake cams fitted, with different width of cams (just wondering if the cam is slightly too wide, pushing the shoes out too far)?
- djh66
Apparantly, speaking to those ITK, I have to grind a couple of mm of the end of the shoes, that make contact with the cam, this should then allow the hub to go on.Donnie wrote:Dave could it just be that there's a few high spots on the new shoes that need a chamfer?
- djh66
Yes that's correct. Done that tonight, hub now fits over brake shoes :anbrgin; However, this is where I encounter the next problem
The 8" hub now rubs on the brake shoe pivot pins! They don't tell you things like this when you buy products, I expect better from SIP. I suppose I'll have to skim some ally of the pins so they clear the hub.
Donnie
- Main scooter: Lambretta Eibar Series 2
I wouldn't have even been happy taking metal off the shoe as you've had to do to be honest
I certainly dont think id be taking metal off the pivot pins especially as then you'll probably have no metal left for the cirlips :-/
Donnie.
