26 years later
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Nice one mate. bet you wont leave that out in the garden again :)
What colour is the frame ? Looks pale blue in first photo then grey or white in others ??
As was said in previous post . cant believe no one knocked about that. or nicked it . must of been out of sight.
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
Devlam
Main scooter: Lambretta Li150 Special
Its a pale green. I couldn't make up my mind on colour so I got some tester pots out of B&Q mixed em around until I got something I liked, brushed it on a spare horn cast I had, sprayed it over with lacquer and then the guy who painted it got it matched. I like the result and I doubt I'll see the same colour anywhere?
Boothy_the_makem
Be nice to see it finished. looking good up to now ;)
stuckintheeighties
Main scooter: SX200
Looking really good.
Just a question about the three hole engine mounts- I was lead to believe these are mounted with the bottom hole at 6 o'clock? Sure I read that somewhere?
Devlam
stuckintheeighties wrote:Looking really good.
Hmmmm.. I should have come back to this sooner. Occupied with other things.
From what I read you're right. Camlam put these in for me!
How much of a problem is this. On the flywheel side I would say the middle hole is putting slightly higher than straight ahead. On the other side the middle hole is pointing straight forward.
Devlam
Year 4 -- so it's been a while, but...
Pretty much finished. However, bit worried about the amount of smoke I'm getting out the exhaust...... :|
bikegunn
Main scooter: vespa smallframe
Looks great well worth the wait
wrecklessrobbie
Main scooter: li150
Did I notice your fork tube bump stop had broken off when fitting the forks.
I have recently stripped my s2. The tube stop fell out. I had to weld it back on.
I don't think you can pass an MOT without a bump stop. Have you rewelded it?
Robbie
Devlam
Cheers Robbie -- It's fixed but I didn't want to weld because it had all been painted. I fixed it in place with JB weld, then drilled and tapped it. Put a couple of bolts in then remove as much metal as I could - then touched up. It looked Ok, but is now hidden anyway. So all good.
wrecklessrobbie
Main scooter: li150
Ah that's good.
The scooter looks fantastic.
Some hard work and effort gone into it.
I have a big pile of stripped down s2 eibar. :)
Am now working on doing a kind of restoration. If it turns out half as good as yours I will be happy :)
