Viton Seals
I see MB's have had seals specially made in Viton.
But Ive been using these seals for Decades and you can get them from any good bearing/seal supplier
Drive side FPM33x50x6AS. These are Viton double lip
Mag side large FPM33x52x6
Mag Small FPM25x42x6
If you add AS on end then youll get the mag ones Double lipped as well
Smiffy
Viton Seals
get them from allseals on roundtree close mate . quite cheap as well
- byron
- Main scooter: Li Special; scarred,but sound
cheers mark, that's the place I was trying to remember to a mate last week...mark wrote:get them from allseals on roundtree close mate . quite cheap as well
- rog60
- Main scooter: Indian GP200
Hi RinB, Have you seen any improvements over 'Rolf' type seals???RinB wrote:Viton Seals
Smiffy
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
I could be wrong, but i believe double lipped seals are to suit something like a front hub seal, where an oil or grease seal is required and a dust seal is required from the outside. Double lipped seals are a waste of time in a crankcase.rog60 wrote:Damn, just got mine from MB and they only sell the drive side and large mag flange ones AND they're only single lip.![]()
The only seals that need Viton are the two internal crank seals as no other seal comes into contact with petrol.
I seem to remember being told in the dim and distant that they wear slower than standard seals, I might be wrong though, anyone have any technical data on them?drunkmunkey6969 wrote:The only seals that need Viton are the two internal crank seals as no other seal comes into contact with petrol.
- drunkmunkey6969
- Moderator
By that i presume you mean they last longer?RobD wrote:I seem to remember being told in the dim and distant that they wear slower than standard seals
What sort of technical data did you have in mind?
That's right, wear slower = last longer. As for technical info I was wondering if anyone had definitive info regarding mechanical properties in comparison to the standard rubber seals, abrasion resistance, elasticity etc
