ELEC-TRICKERY !!
tony172
Main scooter: vespa t5
"there are capacitors available that will work, I have some at home, but I'm working away until the w/e before I can confirm details"
Would be good if you could let me know if you remember :) ..... quite interested in this now for some reason.
Is there any way to search posts so i can check out what you've done twin??
thanks for the replies people :D
rondon
Main scooter: autovespa
sorry to hijack the thread but,, Twin I've looked at some of your auto conversions top quality work sir, have you any exp with 4t autos. I've got an on/of going project with a skipper st motor but having an awful time with the wiring , I've got all new electrical components ( stator, regulator ,coil etc & an unimobilised malossi cdi unit) & a striped down st harness but still can't get it to spark any advice etc most appreciated :fb:
Holly s**t it's got teh rust
ArmandTanzarian
Have a look at burglar alarm batteries. They're quite small.
tony172
well i think iv got enough here to sort my little problem :)
thanks lads!
i think i'll probably be able to squeeze this little bugger in :
http://www.ebay.co.uk/itm/REPLACEMENT-B ... 0679011228
definatley interested in those capacitors though.....
first post on here and iv fixed my problem and learned something new!
glad i came here :D
firekdp
What model's stator are you using?
tony172
its actually a Zip '50' ;)
firekdp
Ah, if it's a 7 wire type stator, then a capacitor, possibly, isn't going to be enough to allow the reg/rec to function correctly.
