S1/2 Horncast question.
clyde
Just a quick question. Might sound daft but would a S1 horncast fit a S2 and vice versa?
clyde wrote:Just a quick question. Might sound daft but would a S1 horncast fit a S2 and vice versa?
Yes mate
clyde
Without modification?
s1 will go on s2 but s2 cast on a s1 will require a bracket mod
RICSPEED wrote:s1 will go on s2 but s2 cast on a s1 will require a bracket mod
What mod?
tea5ive
Main scooter: cometa 140
to fit a series 1 horn cast on a series 2 you need to add another bracket just below the origional series 2 bracket on the fork tube . also the holes need to be slightly wider appart. i have recently done this conversion my series 2 frame. you could get away without doing this i suppose by only using the legsheild and mud gaurd fixings to hold the horncast. cheers simon
tea5ive wrote:to fit a series 1 horn cast on a series 2 you need to add another bracket just below the origional series 2 bracket on the fork tube . also the holes need to be slightly wider appart. i have recently done this conversion my series 2 frame. you could get away without doing this i suppose by only using the legsheild and mud gaurd fixings to hold the horncast. cheers simon
Aaaah I see :D
steve c
with series 2 frame get a piece of 6mm thick ally plate, cut a piece about 30mm by 80mm and drill and bolt to the frame using the original horncasting mounting holes, you will have to jiggle with the measurements and position. the plate is just to support the horncast
then fit the s1 horncast and mark through the mounting holes drill and tap M6 and bolt on, you may have try several times
Beware if your hoping to fit ser 1 bars to a series 2 chrome ring frame. You need to knock out and turn the chrome ring through 180 degrees
series 1 and 2 chrome rings are the same except that the grub screw locking pit is on different sides,
you have to redrill a series 2 one, the lock on a series 1 is at the front and series 2 at the back,
if you dont turn a series two ring around the lock stops will chop your cables with a series 1 headset, and visa versa, just redrill the pit for the locking screw 180 degrees from original one
regards
steve
    Users browsing this forum: Google [Bot], Semrush [Bot] and 13 guests
