SIP Speedo temperature readings
Minority
Main scooter: Li230 S3
Just wondering what people out there are reading for engine temp on their SIP speedo, especially if the sensor is mounted under the cowling bolt as mine is rather than under the spark plug?
Minority
Eden wrote:This means im having to do a rough conversion in my head as im riding for the imperial reading to mean anything to me and me engine.
That sounds like fun! :D
Luckily we are KPH/Centigrade here in Aus so I don't have that problem.
And your right about it just being a point of comparison rather than an absolute, but I thought it would be interesting.
At the moment running in I don't expect to get too hot, but when thats finished and I can give it some stick it will be interesting to see how much hotter it gets :baddevil: .
Minority
Eden wrote:Mounted where you have yours mounted mine read highest racing at cobblesoul 2 years ago reading 78 c but normal riding was high 50's to mid 60's if thats any use to you.
Thanks Eden, that's exactly what I was reading when I went out for a ride today!
WINTERMODEL150
Got my sensor fitted under the spark ( not a sip speedo tho) and see between 170 c - 240 c depending on road speeds and ambient temps.
Dean
sideout
Avanti TT3 - SIP speedo cht sensor bolted to head 124°C
Avanti TT3 - Stage 6 egt sensor 100mm from piston 458°C
Temperature readings are the average of peak values.
sideout
Eden wrote:
sideout wrote:Avanti TT3 - SIP speedo cht sensor bolted to head 124°C
is that bolted to a fin on the head?
yep. :)
simonwwfc
gonna have ago a fitting my sip speedo tomorrow bought a italian speedo cable as well . any pictures on here of any ones fitted etc cables
sideout
simonwwfc wrote:gonna have ago a fitting my sip speedo tomorrow bought a italian speedo cable as well . any pictures on here of any ones fitted etc cables
Didn't do a search on "SIP Speedo" then? ;)
http://scooterotica.org/forum/viewtopic.php?t=20931
joeswoonara
Main scooter: jet ts1
yeah use the search .......there`s a mine of info on there :roll:
