Spanny for Full Bodied Series One
Starwave
Hello
I'm after a spanny for a series one full frame.
It's got a series 3 engine - Rapido 225, LTH reedvalve, 28mm PHBH and the gearing is Italian GP200 with 19/46 sprockets to get 4.8:1 in 4th. Currently I'm using a 48mm Clubman which works pretty well but it looks like it will finally dissolve fairly soon and I quite fancy the idea of a big can sticking out of the side.
I like the look of the SSC Taffy copy but we can't be sure it fits ok.
Under KS Fresco anyone?
Don't want to hack the rear runner but will trim a bit if necessary.
Would rather not spend more than 200 nicker but.....
Any help, suggestions or ideas gratefully received.
Cheers
Starwave wrote:Hello
Cheers
You won't get the clearance with a SSC taffy copy I tried one on my series 1 , NK and adspeed both fit as does JL3 , devtour and Franspeed as I've had all four fitted to series 1+2
Hope this helps Toddy
DigDug
This is a JL3 and it doesn't clear the footboard without cutting it.
Did you have to do that?
cezeta
even the jl3 curly needed the left hand board cutting by the flywheel
Sorry agree re footboards I think you will stuggle with any pipi not to have to trim but the ssc copy was fowling on the panel handle and frame leg
I'm fairly sure that I've got some S2 specific Franspeed pipes, I'll have a look later today. They're closer to £300 than £200 though.
goldeneye
one for sale on here. physcoscottcircle gadgee from ELSC.
Starwave
Nice one, thanks for your help chaps.
I'll pm the Mr Circle.
Cheers
