Winter/rallymaster mudguard brackets
Hi Gaz, I didn't do this conversion, I got Spanish forks, I could measure the collar and come back to you, remind me in a couple of days if I forget ;)
gaz_powell
Cheers Soulsurfer that would be gratefully received
frame and forks will be going to the welders w/c 07/01/13
gaz
soulsurfer wrote:Hi Gaz, I didn't do this conversion, I got Spanish forks, I could measure the collar and come back to you, remind me in a couple of days if I forget ;)
Put the bloody lego down and check it for him Mike :grin:
:lol:
Okay, mine are powder coated so allow for this, although there's plenty of room for tolerances, the height is 16.5mm and the outside diameter is 68.7mm, so aim for 16mm and around 68mm and you'll be fine.
sydduckett
Thanks for the pics and measurements Mike. Im right in thinking they are the correct Spanish ones in the pics that we need to copy? Sorry just being a bit thick...again. Im waiting on a password to be re-sent from photobucket and then i can hopfully get some pics up for advice before i start cutting bits off my forks..... :? :D
sydduckett
Okay, hope these come out. Below are some pics of the Indian Li with turning mudguard now off. Also the pic of the turning mudguard im using with the locking ring attached. Am I correct in saying that the dust cover needs to be discarded then a ring (as per soul surfers measurements) welded in its place?
ta
Sef
And heres on of the scoot itself, will be running as is for a while. In process of seeing if points are up to it before I weigh out on a 12v. Im trying to do this as cheap as poss as i seemed to spent a small fortune on the RB. At some point in the future Id like to put an rb250 in.....but thats for another day.... :D
sef
It looks like you just need to weld the collar on your forks and you're good to go ;-)
sydduckett
soulsurfer wrote:It looks like you just need to weld the collar on your forks and you're good to go ;-)
do you mean under the dust cover? Would I not need to remove this first or can i leave it as is?
ta
You don't have a dust cover on your forks, it's on the frame, this will need removing for the forks to fit.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 13 guests
