Interchanging crankshafts???
20QL
Main scooter: GP 225 TS1
Can a crankshaft from GP engine fit in a Jet or any other series 3 engine casing without any modification and vice versa? I am attempting to build a Li125 engine and have a spare GP crank so I do not want to fork out if I don't have too!
cheers
Luke
carlos fandango
20QL wrote:Can a crankshaft from GP engine fit in a Jet or any other series 3 engine casing without any modification and vice versa? I am attempting to build a Li125 engine and have a spare GP crank so I do not want to fork out if I don't have too!
cheers
Luke
Yes you can as long as its a std. gp crank (ie 58mm stroke and 107mm con rod) it will be fine in a li 125 engine. You will need a different bearing in the mag housing NU2205 and a GP flywheel for a gp crank.
bristolmod
will fit but you will need to have the correct flywheel for the crank. Flywheel side bearing is specific as well (GP vs LI).
The other anomaly is when a TV175 is brought into the equation as their cranks had longer rods fitted
Chris
Scootering since 1968.
^ to summarise the answer to your question is no, not without other expensive modifications
rosscla wrote:^ to summarise the answer to your question is no, not without other expensive modifications
true but its the gp type fly wheel that is the only issue and tbh a gp crank is a worth while modification anyway especially if kitting the scoot at a later date
20QL
Thanx for feedback Lads!
Ha Ha! Anomalies, facts and opinions are always accepted!!
    Users browsing this forum: Google [Bot], Semrush [Bot] and 35 guests
