SIP Lambretta Digital Speedo
Muttlyoo7
Main scooter: Gp200
CANbus wrote:Summing up then, and for the people who purchased this SIP speedo.
Has it been a good investment…… Yes or No??????
Yes! it worked straight out of the box with no fettling required! :bouncing:
Timbo
Yep mind did till a mate fine it tuned now I'm being told to "Use this spark plug Try a NGK BR8ES or equivalent
Halfords stock them
Make sure it has the "R" designation as it stands for resistor. "
sideout
bump... for Pete :)
rapido230
Main scooter: vespa 210 & lambretta gp
ok got mine finally fitted today, easy to set up ....apart from magnetic pickup. got that fixed and went to Adj 3, set wheel circumference 1287, but the gear ratio??? the setting is 00P , so is there anyone who has got a magnetic pick up can tell me what they have programmed in for gear ratio for lammy gp, i can only adjust the 2 numbers from 00 to 29, looked high n low and cant find anything,
any help appreciated,
Paul
Minority
Main scooter: Li230 S3
rapido230 wrote:ok got mine finally fitted today, easy to set up ....apart from magnetic pickup. got that fixed and went to Adj 3, set wheel circumference 1287, but the gear ratio??? the setting is 00P , so is there anyone who has got a magnetic pick up can tell me what they have programmed in for gear ratio for lammy gp, i can only adjust the 2 numbers from 00 to 29, looked high n low and cant find anything,
Paul
Think that means "pulses" per revolution of your wheel, e.g. if you were picking up the 4 wheel studs, you set it to 04, if it's only off 1 magnet, set it to 01. Give it a go and let us know how you get on.
rapido230
aha, thanks, that confirms what i found on a site after searching ages, i'll give it a try, the site said it was how many pulses due to how many magnets etc
Spud
Has anyone tried taking a feed from one of the yellow connections to the Wassell/podtronic & connecting that to the original rectifier for the feed to the speedo?
C*NTSPEED
when those of you who run these on scoots that are not battery feed do you notice the r6 in botton of the speedo screen before it fires up or do i have a fault?
GEMINI S.C.
BLACK WIDDA'S S.C.
carlos fandango
I seem to remember reading that the Rev counter on these speedos dont work with the wassel conversion ( or did i imagine that ?) dont really want to read all 13 pages :oops: so is any using one with a wassel conversion ?
Ive got a Koso speedo (not the lambretta one) and i cant get the rev counter to give a stable reading, so before i send it back as faulty, would the wassel conversion affect it ? i cant see how it would :? The rev counter works from a wire wrapped around the HT lead.
sideout
carlos fandango wrote:I seem to remember reading that the Rev counter on these speedos dont work with the wassel conversion ( or did i imagine that ?) dont really want to read all 13 pages :oops: so is any using one with a wassel conversion ?
I've now got a couple:
1. GP with full DC Wassell conversion, the rev counter won't work with a battery in the circuit :( but everything else works fine if you use a resistor plug as they advise. I also run a Koso "GP" rev counter on this bike with 10 turns around the HT lead, works fine :)
2. Li with usual 12V AC, everything works fine as it says on their advert.
Eden wrote:Has anyone tried the speedo in a winter model headset?
I really want another for my SX but they seem a bit slow in bringing one out to fit. I know the Spanish Winter Model headset is similar, but I think it's bigger so may well fit. The problem is the location of the speedo drive thread relative to the hole in the top of the forks where the cable attaches.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
