Direct cooling flywheel cowl
jaffa1
Main scooter: series 1 framebreather
Hi,
Iam currently converting the motor for my cutdown to direct air cooling, scoop under barrel etc. I have modified the mag housing and am planning on making a suitable flywheel cowl. so far so good, however i am a bit stumped as to how to fix the cowling to the mag housing.I have seen race machines with this conversion but the cowls are fixed with what looks like several jubilee clips joined together around the circumference. my question is: is there a better way of doing it? Any advice, especially with photos, would be very appreciated.
Many thanks,in advance,
Jaffa.
WINTERMODEL150
I'll put some pics of mine on here when I'm home later
Dean
WINTERMODEL150
This is what i come up with ,x3 m5 screws cur down so they don't rub on the flywheel
Dean
jaffa1
That looks really good, and pretty much what i was hoping for, thanks dean
Terrible Taff
Main scooter: Lambretta's & Vespa's
Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
WINTERMODEL150 wrote:This is what i come up with ,x3 m5 screws cur down so they don't rub on the flywheel
Dean
Did you make this? If you did what's the cost as this is also something I am after!
Is it fibreglass or spun alloy?
Cheers, Ian
Ian T Frankland
Taffspeed Design Innovations
Mob: 07971 818693
Email: [email protected]
