OAP
Simplex,
For the moment put an X7 needle in on the 2nd notch, air screw 1.5 - 2 turns out, if you cannot get it to tick over within 10 mins you may have an ignition issue. Give me a call.
CANbus
I would usually read through a thread for a possible answer, but come on many pages now...
So can I ask is anyone running this kit with a ScootRs exhaust?
As anyone had one a dyno?
If yes what's the performance like??
11111111 = 0xFF
The ScootRs exhaust is quite revy so I wouldn'r have thought it would suit the Avanti. It wouyld be better to sell it and buy a JL3 or similar.
CANbus wrote:I would usually read through a thread for a possible answer, but come on many pages now...
Well close..Im running a PM25, when Dan fitted and set mine up, by far the Franspeed race came out on top.
Dan wrote:Image
Bearing in mind, that this kit is straight out of the box, no porting/tuning to cylinder or casings, simply bolted on and run up on the dyno (on a rich setting) that 22bhp @ 6000rpm and 17ft-lbs torque @ 6400rpm is pretty impressive. There are not many kits that will do that straight out of the box, and if they do.....they are not piston port, are usually producing the power much higher up the rev range, and usually cost a lot more! lol
CANbus
Andy, Coaster.
Thanks for the reply, I have a JL3 race on now (I think..thanks John).
I will start a new thread with my issue, this isn't the right thread to post it.
11111111 = 0xFF
CANbus wrote:Andy, Coaster.
I would have said give Ron a call if you are having issues canbus, he is very helpful and has loads of data and info on the Avanti
CANbus
Andy,
I have no problem with the kit, like you I'm very impressed with it.
My issue was the rear mounting bracket on the JL3 exhaust,
11111111 = 0xFF
Post your problem with the bracket in another thread mate loads running them, could it be the issue when it's tight to the barrel? That's why the franspeed avantI race was designed..
simplex
simplex wrote:Hi Kit 99 did its first few miles last night on the way home.. very boggy ..
delorto 30 PHBH
50 pilot
AV266
x13 (2nd from Top)
122 main
Franspeed race
LI 150 box (italien) 4.8
Slide 40
Changed needle to x7... better but still a tad rich.. The slip joint on the Pipe by the kick start is chucking oil out.. At 200 miles do I put up with this for a while then start weakening off after fully run in?. anyone used one of the rubber covers on the joint?
Jazzy
dont down jet,
make sure your ignition is in tip top condition.
sounds mad but try the x13 2- 2.5 from top with a 62-65 pilot.
people have mistaken rich for weak at 45 pilot you will hole a piston on a run.
    Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
