A couple of Ts1 questions
Darrell Taylor
Main scooter: LAMBRETTA
WINTERMODEL150 wrote:Ok,this is what I ended up with after modifying the side panel so I can now run an LTH air filter under the panel.
All comments welcome!!
Dean
?how many times you cracked your shin on the kick start pedal :)
WINTERMODEL150
Dean
I need a big pedal what with all that compression :D
clockwork
Main scooter: gp 150 tuned
soulsurfer wrote:In progress as we speak Dean?
Another idea might be a pair of wider Series 5 panels :idea:
Like the look :freak: of that mate....
Hopey
Main scooter: lambretta Gp 225
i use a lth manifold with a 35mm mikuni under gp panels with a cam lam sweetbreathe filter, this setup does not touch the panels and solves the fuel spitback issue, ran this for over 2k miles without problems
nelson pk
Great idea with the mod on the panel there!
The breathe sweet is good, i run it on a monza with a PHBH and it just touches the panel slightly.
The real problem is when you want to use the filter with a mid range fuel tank and toolbox or a long range tank. The filter then has no room.
This is why i'm removing the standard toolbox and going for a legshield toolbox on mine.
This will then give the filter plenty of room.
