asso rings
handofdave
Main scooter: li ts1
after much ringing around i am finding it hard to get a set of 62.6 asso rings so if anyone knows where i can get a set please let me know,rayspeed said they will not order any more asso pistons or rings untill they have sold all there mahle stock, so is there any body else who orders from asso?
Adam_Winstone
Why not fit the same spec' Mahle rings, which appear to be at least as good/reliable as the Asso rings? Otherwise, buy some 62.8 rings and gap them with a fine file, which will actually allow you to control your ring gap anyway.
Adam
handofdave
hi adam thanks for the reply ,have searched for 62.8 rings and those are unavailable too,completely ignorant toto the fact that the mahle rings were the same spec so will try that
cheers
dave
eibarlad
I've had the same problem with a 67.0 mm two ring ( 1.5mm thick ) asso. No new rings available.
Is there another type/ make of rings I can use.
Adam_Winstone
eibarlad wrote:I've had the same problem with a 67.0 mm two ring ( 1.5mm thick ) asso. No new rings available.
The Mahle thin ring pistons and rings that AF sell are a direct copy of the Asso. Enquire to see whether AF have any of the 1.5mm Mahle rings available at 67.0mm. AF have recently spec'ed 1.0mm rings on the latest pistons but they still hold stock of large quantities of the 1.5mm Mahle rings.
Adam
