bush or needles ?
I need to replace the rear bearing, so am collecting bits for the job.
I currently have a camlam bush in the crownwheel, but have a pair of needle bearings that I was planning to use in the next build.
but which is best ?
I'll be fitting a camlam lightened crownwheel
thanks
I have heard that the bush is the stronger option Jarv, perhaps someone can cofirm :?:
cheers colin
or, reading in Sticky's book earlier, is the bush used cos the crownwheel is not hard enough to take the needles ?
noggin1969
The CamLam ones run a bush , if it hasn't already cut a small groove with a hacksaw across the bush to aid lubrication. You'll see the CamLam crown wheel come with a small hole were the bush fits to help with this to.
Has a mind full of useless s**t and isn't afraid to use it !
noggin1969 wrote:The CamLam ones run a bush , if it hasn't already cut a small groove with a hacksaw across the bush to aid lubrication. You'll see the CamLam crown wheel come with a small hole were the bush fits to help with this to.
thanks, I hadn't noticed that yet, I'll go bush.
noggin1969
Aways better to go for the bush :moon: lol
:lol: indeed
this thread was innuendo laden from the start
pete
Sorry to butt in on this thread,but does anyone know how tight or loose the brass bush should be.I,ve just fitted one and filed the grooves etc but it was a very tight fit,ie forced on,is this ok.Cheers Pete
pete
I dont really want to pay 20 quid to maybe or maybe not get an answer to this one,Anyone?
Cheers,Pete
noggin1969
Should be a good fit but not to the point were it won't turn in the crown wheel
    Users browsing this forum: No registered users and 24 guests
