Dangerous? Its bad enough wearing a helmet which blocks out noise.dapper wrote:Ear plugsNo seriously, I always ride with them in with a Clubman fitted to my scoot. You can hear your engine through your body (vibrations) cuts out wind noise etc. so you can hear any out of the ordinary noises.
Quiet Clubman
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
Scootering since 1968.
As Special X says, it depends on the particular engine, I have a couple of standard spec 200`s with AF Clubmans and they are quite reasonable, but I have recently carried out some work on a mates 200,with one of those ally/iron liner top ends, with an AF Clubman, while I had the cylinder off I thought the exhaust port looked biggish, and sure enough when the scoot was running you could hardly hear yourself speak, even when it was ticking over.
Keep on keepin on
- Muttley McLadd
Ear plugs cut out the wind noise more than anything else. If you're doing over 40mph, the wind noise does permanent damage to hearing.dapper wrote:Ear plugsNo seriously, I always ride with them in with a Clubman fitted to my scoot. You can hear your engine through your body (vibrations) cuts out wind noise etc. so you can hear any out of the ordinary noises.
Anyone riding without ear plugs in these days must be retarded.
my mk1 ron moss clubman was quieter than my "normal" af one
think he ma be bringing out a mk2 with better spread of power
cheers
mick
cheers
mick
Train Driver
Mr dapper well said about the ear plugs, us oldies have to look after our hearingdapper wrote:Ear plugsNo seriously, I always ride with them in with a Clubman fitted to my scoot. You can hear your engine through your body (vibrations) cuts out wind noise etc. so you can hear any out of the ordinary noises.
CPH Lambretta
- Main scooter: DL 150 1970
What about a standard Italian GP150/200 exhaust (for that original lambretta sound)
The rest of my set up is :
22mm jetex,175 with mild tune (EX165,Tr122,IN136) and 5.2 gearing
Slow is the new fast!
- Information
Who is online
