Improving Lighting?
purple_pill67
Main scooter: Jet200
ArmandTanzarian wrote:
purple_pill67 wrote: to fit a H4 conversion block.
Does anyone sell these ready made?
Not as far as I know. MB enquired iirc and min
1000 order/£30 cost price or summat as daft.
Its fairly easy to bodge yourself....i got the info on lcgb.
The speedo bulbs are same fitting as car interior lights so I got them on ebay for under 2 quida pair posted....they are dc so you need to do wassell too.
purple_pill67
goldeneye
you can get a halogen bayonet fitting bulb, plugs straight in. use a l.e.d. speedo bulb and festoon bulb. i ride on unlit country roads to work, and it works well, on a SX headlight. Beedspeed do the bulbs for about 4 quid.
Don't get the one from Beedys without the filament shield though....
faf
Main scooter: GP 230 Mugello
Wiil the H4 conversion work on an AC system?
Yes
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
I bought the standarb bulb in a 40/45W format from my local motor factors for about £4. My previous bulb was a 20W and useless. I also converted to full DC
I get my kicks out on the floor.
dapper
Halfrauds do a straight fit 35w/35w halogen with shield for about £6 in their Bike It section Packet Number 417
servetakid
goldeneye wrote:you can get a halogen bayonet fitting bulb, plugs straight in. use a l.e.d. speedo bulb and festoon bulb. i ride on unlit country roads to work, and it works well, on a SX headlight. Beedspeed do the bulbs for about 4 quid.
TBH, that sounds like what i need. I will have a look and make sure i get one with a shield...
Rich_T
Main scooter: Li Special
All the power and bulbs in the world won't make a difference if the loom and switch are a very cheap pattern part.
I rewired a new handle bar switch switch a couple of months back and found that although the power wire looked good and chunky, it actually only had 3 or 4 strands of very thin conductor in it. On a headlamp bulb this will make a very big difference.
