BGM Lambretta crank 60 x 110mm
Lambretta Sash
Main scooter: Lambretta TV 230
Any one tried to fit one of these yet ?
I get 1.3mm clearance without shims supplied fitted!!!!! on an italian 200 casing
WTF happening here, i thought and tried the old crank and it was fine with 0.55mm clearance.
Best measure the shoulder where the seal sits, the BGM item measured 9.32/9.29/9.30mm
That then lead me to check other cranks Inocennti, MEC, Mazzucchelli, Omega and Indian which varied between 8.29mm and 8.48mm
So, i'm curious if anyone else has fitted one in an indian casing and what clearance you got ?
Dryballs
Where are you getting clearance?
mickdale
are you saying the mag side crank web sits further in the casing - thus further away from the mag flange?
Lambretta Sash
I was measuring between crank web and drive side plate once the front sprocket had been tightened up. Usually find this 0.4 to 0.6mm.
It turns out the cranks are machined wrong with too much width on the shoulder where the oil seal sits.
Sent it back and waiting for replacement which seems a bit long in the tooth coming, several emails with promises but over a week waiting now!!
davepeters
Main scooter: px200efl
Hi There.
Thinking about getting ones of these cranks. Did you eventually get yours back? Would you recomend it if so?
Cheers, Dave.
rapido230
Main scooter: vespa 210 & lambretta gp
i got 1 with no issues , in fact it superb and so smooth
Lambretta Sash
Crank has been in for a while and no further issues to date.
Its taken a good hammering up the sprint track, Lcgb 65th and Mersea and is very smooth
So yeah after the initial issues its turned out to be a good buy
One batch had clearance issues....BGM will exchange.
davepeters
Cheers for that.
Lamaddict
Is there anyway you can identify the bad batch apart from the oil seal shoulder issue?
