No, the only one that's been running an un plated cylinder is Sticky.
Bit busy right now, I want to answer some previous posts in the next couple of says
We found the same on mine while dyno testing at Diablo.OAP wrote:On Another note: just a quicky, running rich?
If you are running a PHBH check your floats, had 2 floats in one bike filling up with petrol, Geoff Stephens has just phoned me regarding another one of my kits, same problem! so is this due to ethonal in petrol.
Sending 2 back to Dellortos today.
I have had this myself on another setup but checked mine on Saturday and all the float was fine. Scoot wouldn't start at all (it was misfiring badly when i last rode it) and found no spark :wtf: Eventually changed the stator and still no joy, fault eventually traced to a high resistance in one of the connections to the AugustoOAP wrote:Sorry should point out only one of the double floats in all three cases is leaking not both.
