A Little Lubrication
I generally go dry cause i like the friction :shock:
Ohh errr Missus. :o
warts
Main scooter: honda
It'll get all ruff n' sore.
tavspeed
make a funnel at the end of the cable out of masking tape,plasticine or bluetack,support vertical and as muppett says fill with gear box oil and leave over night,job done.
red
tavspeed wrote:make a funnel at the end of the cable out of masking tape,plasticine or bluetack,support vertical and as muppett says fill with gear box oil and leave over night,job done.
Why,as it's a speedo cable inner,take it out of the outer,lubricate and replace. :biggrin:
At least you won't do the last 6 inches as recommended
