cable routing for reverse pull disc set up
Supereibar
Evening chaps, just wonder if the cable should go in front of the steering column or behind it? :?: I realise that it could be placed either way, however my concern is the clearance off the weel. I also realise that the cable needs to be hold by the coat hanger thingy that I need to fabricate...
Kind regards,
Jaime
victor
Main scooter: Tv175 but currently a SS210 :)
I fitted a cable holder professionaly made, laser cut, but found it to keep the cable in a slightly wrong angle.
So instead i fitted the cable to the fork at the center of the wheel using a very loose zip tie. If I remember I can take a photo of it...
if i recally correct jason frost does a nice lazer cut cable guide/support i think though you will need dampers to attach to top stud (im assuming this is for your jet btw so on probs there ) cable i would expect to be in the same place more or less certainly at the head set end
victor
RICSPEED wrote:if i recally correct jason frost does a nice lazer cut cable guide/support i think though you will need dampers to attach to top stud (im assuming this is for your jet btw so on probs there ) cable i would expect to be in the same place more or less certainly at the head set end
That's the one I got, looks the piece but didn't work well (for me). Probably others have had better results...?
Supereibar
I am still confused about the routing.. So should I place it in front of the steering column or behind it?
victor
I'll take a photo later, think only one way works though...
Supereibar
Thank you, I am doing a dry build of the entire system, I need to know the precise length of the cable and it is imperative that I route it correctly before doing any cutting...
victor
Look at my Flickr account, youll find it in my SS 180 resto thread
victor wrote:Look at my Flickr account, youll find it in my SS 180 resto thread
will need a link mate
twin
i have just done one and put it behind
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 17 guests
