R1 shocks or escort
storkfoot
coaster wrote:
Fair point but that is just based on assumptions, does anyone KNOW that the the valves in an R1 are unsuitable or is it just ASSUMED that they are wrong. The R1 shock conversion seems to have been the performance choice for several years now but now seems to be questioned (quite rightely in respect of the bushes) because there are a couple of aftermarket shocks available all of which seem to have issues of their own. I would just appreciate some objective and factual opinion on the subject rather than conjecture.
I confess to having only just fitted an R1 shock having had it pointed out to me on the Eurolambretta trip that my rear end was bouncing a lot (I hope it was my scoot he was talking about :oops: ). That was with an Escort fitted. I've only done 20 or so miles with the R1 whcih is fitted with a 180lb spring and the difference is amazing and I haven't touched the preload or rebound settings yet.
Informed comments welcome ;)
Yes, Col, I can testify as to your bouncing rear :P Are you sure your shock was an Escort? There's a lot of fake Escorts around.
I once saw a post from Ian Frankland (Terrible Taff), I think, which talked about the bushes on R1s and Hagons being wrong. The correct bush should have the inner part wider so when the shock mount nut is tightened, it tightens on the inner allowing the shock to "float."
Personally, I wouldn't use an R1 shock out of choice again because of this issue with the bushes. There are lots of decent well made rear shocks for Lammies these days so why risk it?
Having said all this, at present on my cutdown, I have a Hagon (one of the recalled ones with re-machined bushes) but I would never ride two up on that :bigsm:
storkfoot wrote: Are you sure your shock was an Escort? There's a lot of fake Escorts around.
I can vouch for the fact that it said Escort on the box, it's chrome plated and was of the correct 300mm length, got a similar one on the LiS but they both came off ebay sellers so I guess it's anyones guess as to authenticity ;)
Before fitting an R1 check the length as they are not adjustable in length i found them to short for a series 1/2
Eddie15b
Main scooter: gp200e
"I finally installed urethane bushings instead of the rubber ones on the rear end, which made a great difference"
do you happen to have a link for the rear shock urethane bushes and where i could buy some?
thanks
Lamaddict
I've used quite a few R1 shocks and always used the nylon bushes, spacing washers and don't over tighten them. I can never understand the settings, I know there's a sheet but can't get my head around it. I'm about 14 stones and have the shock on my TV S3, normally ride one up, so any suggestions on the settings?
Indian Escort ones are decent shocks IMO but Yam have to be better if you set them and put them on right. Normally the Yam ones just seem to feel better for me and they look good.
victor
Main scooter: Tv175 but currently a SS210 :)
Eddie15b wrote:"I finally installed urethane bushings instead of the rubber ones on the rear end, which made a great difference"
thanks
Old rubber ones
New urethane compared to old rubber version
Installed
Bought them directly from Jettin in the states, arrived in italy in about 10 days or so
goldeneye
got an R1 shock on the "pacemaker" re bushed by a mate , nylon i think...he knocked them up at work for nowt...and a 225lb spring by "shocky" off here. best rear shock ive ever had on a scooter. i run an Escorts indian one on the GP , and its great for the money also . we used to do 2"s up all over the place with an Escort shock on the back, and ive never had one fail. one is an expensive good looking shocker that works, the other is a shocker that works.
Yanker
Escorts are a great budget shock IMHO and perform and last well for the price. But compared to a Taffy, R1 or Pro-Tec, very basic and in a completely different league.
As Toddy says the R1 is too short for a S1/S2 with a 295-300mm shock the back-end sits veriy noticably way too low.
Moved over to nylon bushes for my R1 as the eurethane ones did not last. I'd say spacer washers and 'Chiggy's' m16 nylock 1/2 nuts are the way to go with the R1.
The Taffspeed/Pro-Tec are great. Anyone tried the Sacci/Cambridge 'Ultimate' yet. That is height adjustable so will suit S1/S2. (Wish I had the budget for one :-( )
Are people using bushes other than the ones Foxy made?
Mine have been in for many thousands of miles, without a problem.
Muttley McLadd wrote:Are people using bushes other than the ones Foxy made?
Are they still available Mutley, contact?
