indian 225 kits
stumpy
Main scooter: gp150 1972
Are they any good ?are they to be avoided ? will they fit in a italian gp150 engine ?
Thank you . :baddevil:
bristolmod
some; some; no (stud spacing)
Scootering since 1968.
stumpy
This is what i was looking at .
Once youve slung the piston in the bin and had a top tuner rework the rough barrel and head yes they can be good :D, theirs ton of pages on here asking the same, do a search..seems sodding cheap like..
stumpy wrote: This is what i was looking at .
As Bristol Mod said, they are for the 200 cases, the stud holes are different. You need the 185 kit which you will also find on ebay. The quality can be a bit hit and miss, the ports will probably need tidying and the piston to bore clearance will need to be checked and honed if necessary.
stumpy
thank you both :bigsm:
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 8 guests
