TS1 245 38bhp / 26.14 ft.lbs
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
Darrell Taylor
Main scooter: LAMBRETTA
Heres a dyno graph of a ts1245 ive dynoed today
running on
one of my cylinder tunes
and modified heads
62/116 crank 71 bore
fran race
35mikuni
vf3
Absolutely cracking result there Darrell.
Did you shorten the tuned length of the pipe to accomodate the over-rev to 9k?
tonydevon
Main scooter: '71 GP125
BLIMEY, crackin result
Bleeding nora :o..gis a go..please.
WINTERMODEL150
Well done Darrell cracking result again :D
Dean
Yanker
That graph looks absolutely 'top-tastic'...the torque figure! :frog:
Darrell, do you think it would be realistic to do a 'similar' (de)tune, shifting the power delivery 1k down without sacrificing more than 5 BHP and 4ft.lbs. ?
Anyway: Gratulations!
Andy
Darrell Taylor
drunkmunkey6969 wrote:Absolutely cracking result there Darrell.
ta.
no its a standard pipe,ive played with tuned length before but moves the rpm that it comes onto pipe up from the regular 5400 to near 6k which leaves the gearbox struggling
its also on straight line ignition
its 9k overrev is often seen on most motors but nosediving ,not holding on like this does
Darrell Taylor
Yanker wrote:That graph looks absolutely 'top-tastic'...the torque figure! :frog:
Andy
moving power down is fairly easily done torque would actually go up and power drop a few
but this motor sits in top at 30mph and pulls away clean as, pulling from 5000-5500 is about the usable limit of the 4 speed box so as long as you tune to that and gear appropriately you get a nice motor
Darrell Taylor wrote:....but this motor sits in top at 30mph and pulls away clean as, pulling from 5000-5500 is about the usable limit of the 4 speed box......
What gearing are you running? Wouldn't 5500rpm be circa 50-55mph?
Muppet
I read it twice before I got it I think he's saying when it's sitting at 30 it feels like another motor would a 5500 and pulls away as it would if doing 5500 revs but In reality it's pulling less than 3000 but moves away just as easily,
muppet,
C’est la vie
    Users browsing this forum: No registered users and 42 guests
