running on
one of my cylinder tunes
and modified heads
62/116 crank 71 bore
fran race
35mikuni
vf3
38bhp / 26.14 ft.lbs
ta.drunkmunkey6969 wrote:Absolutely cracking result there Darrell.
Did you shorten the tuned length of the pipe to accomodate the over-rev to 9k?
moving power down is fairly easily done torque would actually go up and power drop a fewYanker wrote:That graph looks absolutely 'top-tastic'...the torque figure!![]()
Darrell, do you think it would be realistic to do a 'similar' (de)tune, shifting the power delivery 1k down without sacrificing more than 5 BHP and 4ft.lbs. ?
Anyway: Gratulations!
Andy
What gearing are you running? Wouldn't 5500rpm be circa 50-55mph?Darrell Taylor wrote:....but this motor sits in top at 30mph and pulls away clean as, pulling from 5000-5500 is about the usable limit of the 4 speed box......
