lambretta front suspension, whats the options
tonydevon
Main scooter: '71 GP125
currently working on my project and looking towards sourcing the bits that I will need to finish it etc
I only have bare forks, so thought why not just look for external suspension from the off
I did see but cant find them again, a pair of suspension units with mounts on ebay, was about £100 with brackets etc, are they any good? looked a bit like monkey bike shocks, I did look down that route, but all too long
Im assuming that the escort dampers I see will need me to have all the internal springs and bits and bobs.
I am going for the racer look so quite fancy the look of the external units, I seen BGM units but at over £250 they seem a lot of money, are they that much better than the cheapy ones, or just more adjustable for track use etc? is it more a case of they are what you need but the cheap ones are really bad LOL
I dont and wont be riding fast, but I cant afford to buy things twice if somethings total rubbish
smoore-gt225
Main scooter: lambretta GT200
hi i run bgm's on my tv and they are great but you still need the internals with them
cheers steve
Lamaddict
Start off with the Cam Lam internal yellow progressive springs. I think the BGM ones seem a bit OTT but I've not used them. The Scootrs stainless ones seem OK to me and together with the progressive springs it's not too stiff or soft fhar, fhar :)
frank sanderson
If its outboard shocks your after have a look on here www.lambrettainnovation.co.uk there are loads of scoots fitted with the correct ones on here also look at the SCOMADI scoots they have our upmarket BITUBO shocks fitted which cost about the same as BGM dampers . we dont sell on ebay so any on there are copys of our originals .The problem with outboard suspension is that unless you have genuine italian or spanish trailing links you cannot weld the lower pins to the links The matl that Indian and any copy links are made of are not suitable for welding to and the pin will break off . The people that are selling the kits you have seen will sell them to anybody without making them aware of this problem. we sell the correct shocks for £90.00 and will weld the pins to your links for £30.00 if you want to have a chat about suspension call me at unit o1772 721714
ta Frank
Timbo
Those BGM dampers are the dogs wotsits, not cheap but worth every penny.
tonydevon
Many thanks Frank. Yes them bitubo ones are sexy as hell but dont think i can afford right now. I will give you a shout sometime for a pair of them lower priced ones. Im making my own links so dont have to worry about the link quality.
carbon lammy
had bitubos on my lammy for just over a year wont have done 1000 miles both shockers are now leaking oil,decided to fit bgms smoother ride look more standard,as usual bitubos just out of warranty not good to pack up with only a few miles on them.
Baggy
Agree with Frank, re welding the stud bosses to the links. I've welded dozens and only use Innocenti or Spanish. Always TIG weld them too. The quality of the casting of some Indian and pattern links is appalling imo and not worth the risk.
i got some out board type off ebay .. think they were for a kids quad bike .. about 5mm longer than the ones frank does .. i still have them and i doubt id be using them tbh
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 6 guests
