Fitting a reed valve to rapido
harpo
hi im fitting a reed valve to my rapido 225 where do i put and how long for boost port thanks
harpo wrote:hi im fitting a reed valve to my rapido 225 where do i put and how long for boost port thanks
It needs to run up from the inlet port and finish level with the top of the transfers somewhere around 22 - 25 mm wide but check where the ring pegs are. The depth will depend on the amoununt of metal you have to play with. When I cut mine into an SR 225 type barrel i managed to break through to the outside between the fins :shock:
I'm sure one of the professional will be on soon but in the meatime, try the search facility, this has been covered in some depth with pictures before.
wack 63 wrote:Have a look thru these http://www.lambretta-images.com/archive ... play_media
It says that album doesn'y exist :?
Just worked for me?
wack 63 wrote:Just worked for me?
Tried it again, still getting....... Error The selected album/file does not exist! :?
harpo
Thanks for the info lads think i'll buy a ts1 piston don't know about cutting the rapido piston might weakin it to much
