Gearbox Problem?
Bilko
Main scooter: LI150
When I was coming home from Lincoln I developed a problem just outside Liverpool.
When accelerating I had to go steady and anything over 4K gears would disengage with a clunking sound. Dropping the throttle back it would be ok.
If I accelerated too quickly it went out of gear.
Any pointers before I strip the engine?
Bilko's Oily Blog
bazman
Hi Bilko, was it when under hard accelarating like jumping out of gear/missing?
If so more than likely to be your front sprocket/shoulder worn and spinning on itself, i had same sypmtoms earlier in the year.
Baz.
Bilko
Main scooter: LI150
Aaaah never thought about that.
I was thinking of the gearbox
Yes, I open the throttle hard gearing misses. There's no jolting or jumping like a loose gear cable.
Thanks Baz.
Bilko's Oily Blog
bazman
Hopefully an easy fix fella :D
Bilko
Main scooter: LI150
Thanks Baz.
It happened once very quickly at Lincoln, but then nothing til the last few niles.
Bilko's Oily Blog
Bilko
Main scooter: LI150
EDIT:
Tried to kick it over for the first time since I got back from Lincoln and the kickstart dropped hard without engaging.
Thought there was no oil in my haste to check. Of course, I undid the level plug. :oops:
Bilko's Oily Blog
Bilko
Main scooter: LI150
Loose chain, really loose!
Bilko's Oily Blog
    Users browsing this forum: Amazon [Bot] and 2 guests
