rear hub seal
Tosh
can i replace the hub seal without stripping the engine just noticed a small leak ,thought i might be able to slide a new one down over the shaft after i take the metal plate off and the thin metal plate under that one
Agent Buchwald
Yes, no problem, a bit trickier getting it in nice and square because the layshaft is in the way but has been done successfully more than once. All the best.
Tosh
thanks for that Agent Buchwald will give it a try.
Paul
    Users browsing this forum: Semrush [Bot] and 30 guests
