Foam air filter/TS1
TS1-200
Just about to fit one of those foam air filters to my TS1 at last, have been running without a filter for years, but have decided to give one a try, any idea if and how the jetting might change, its a Delly VHSB 34, running a 170 M/J at the mo.
Keep on keepin on
TS1-200
No its just a straight filter that fits on the air intake of the carb, its just that a mate of mine who builds a lot of engines says he has seen some motors that have run without an air filter worn out after a 1000mls,I just didn`t like a big hole cut in the panel with a lump of sponge sticking out, but he`s got me worried now !
Keep on keepin on
GP Kevo
What eden said! Filters on both my TS1's. If you use foam filter oil you may find it more restrictive making your jetting seem rich.
wax
I am interested in a filter for my TS1. Has anyone got any snaps of these? Do you have to clean them / change them often?
camel
crikey what are all those pipes?looks like somebodys ticker
Muppet
Loo kin like its got a drink problem, are you a member of fuelaholics anonymous?
muppet,
C’est la vie
mnpes
Ran the Madspeed Ts with a filter pad bonded to the side-panel
Pad sat against the carb inlet nicely ~ Worked a treat
No Big Hole
Lambretta net (USA ) did sell one similar to the sweet-flow
E-mail them
Timbo
Got any pics?
a.j
I've spent over £10 so far in jubilee clips where the git keeps falling off the carb. How can I stop the elbow coming off the carb?
warts
Main scooter: honda
You can drill a hole or two through the jubilee clip and once fitted, put a small self tapper through into the inlet stub, it only needs to press firmly onto the carb.
A bit of trial and error to get the correct size hole for your self tappers may be required. I used to know s**t like that but my heads f@@ked now and its all gone.
    Users browsing this forum: Google [Bot] and 9 guests
