Fuel Starvation
Interesting. I'll have to have a look at that.
Mel K
Pull the fuel hose off the carb, put it in a clean milk bottle, turn petrol on. Time how long it takes to fill the bottle, not exactly sure what the rate should be but someone will know if you put your results on here, I think it should be a pint a minute.
rbgaz
how-far-will-it-go-before-it-conks-out
i-say-this-as-sefton-had-this-prob-couple-weeks-back
it-would-start-fine-then-die-after-half-mile
after-a-lot-of-fecking-about-it-turned-out-when-he-sat-on-scoot-it-was-kinking-the-fuel-pipie
rbgaz wrote:how-far-will-it-go-before-it-conks-out
why-do-you-put-a---dash---between-each-word-instead-of-a space ? :D
rbgaz
lol-i-hav-no-space-key-after-knocking-bottle-wine-over-it-- :oops:
maskie66
:-) :-) :-) lol
warts
Main scooter: honda
check your hole. ie try without the filler cap.
(I've spilt various beverages over my keyboard. I get all sticky fingered).
Yup; done that warty.
Would I be correct in thinking that an air leak would mean it isn't drawing fuel properly?
Ha ha ha ha.....brilliant. :grin:
Triken
Main scooter: 200cc Trike
no-one else has mentioned it so I will. Have you got an in line fuel filter on your scooter?? Have been known to create a vacuum in the supply pipe, starving engine of fuel.
