pre dyno adjustments
mk1
hi,think ime booked in for a tune this weekend with a couple of mates,after having a af 225 rapido kit go tits up then a af race crank ive now fitted a indian alloy barrel 200 kit and crank,the eng is fitted with a 30mm oko flatside carb(do you stock the jets for these?) and a reed valve manifold with a sterling exh.
The eng runs well but seems to run out of steam on banks and when opened up,plug is a nice dark brown colour after a good hard run,is there anything I can check and adj before I bring it in?
cheers mk1
Got Kenny, Loui and Mark from M'boro coming this weekend.....which one are you? :lol:
Nothing needs adjusting as such, but the scoot does need to be in reasonable running condition before it can go on the dyno :lol: :lol:
We'll just need to have a chat on Sat before we get started about spec of machine, known existing problems and what you're hoping for etc, then we can have a look.
We carry Dellorto and Mikuni spares in stock, and if there's anything you need that we dont stock, we can discuss what you need to buy before you leave.
Dan
mk1
drunkmunkey6969 wrote:Got Kenny, Loui and Mark from M'boro coming this weekend.....which one are you? :lol:
Dan
ime Louis 8-) kenny`s a bus spotter so if you have any pics it will make his day,and mark looks like frankinstien who`s fell asleep on a sunbed lol,how do you rate these oko carbs?
is there anything I can check as to why it dies on hills to save on dyno time?
oko carbs................
i would,............ erm .........not rate them at all................ :shock:
others may disagree of course.............?
I've heard from others that they are a cheap and functional carb, but can be a bit hit & miss, some batches are OK, some are not.....
mk1
ok,we`ll see how it goes on saterday and go from there :roll:
OK Louis, see you, the bus spotter and Frankenstein on Saturday! :lol:
mk1
just like to say got the scoots dynoed today and a big thanks to the Scooterotica crew for a warm welcome,sound advice and a good service,not behind closed doors like other outfits ;) so get down there if yer scoot needs sorting :mrgreen:
Cheers Louis, nice to meet you Kenny and Mark.
Give us a shout if you need owt else.
Cheers
Dan
