the lammy, cold, with choke on, it bursts into life first kick, but it burbles and if I open the throttle it dies. It will rev normally after 30 seconds. Any ideas? too big pilot?
cheers
when starting
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
Crystal balls a bit iffy at the moment I'm afraid........................
Engine spec; carb; jetting etc please.............
Scootering since 1968.
- djh66
- registered user
- Main scooter: 150 special
- Contact:
GT186 24MM PWK BREATHING THROUGH RAM, GJH NEEDLE (MIDDLE CLIP), 118 MAIN, K34 PILOTbristolmod wrote:Crystal balls a bit iffy at the moment I'm afraid........................
Bring Me Sunshine COYH
- Rich_T
- Dealer
- Main scooter: Li Special
- Contact:
If it revs alright after 30 seconds it isn't the idle just it is most probably the choke jet size but either way what you are describing is completely normal for a cold start on a choke, even my NC30's do it.
As a word of advice for all Lambretta engines, I wouldn't advocate gunning any engine from a cold start until it had ticked over for a bit and at least got some warmth into it.
- djh66
- registered user
- Contact:
Other than that, RichT, the GT kit is running great, still got to get a few more miles on the clock to run it in, but I will mail you my final carb spec. when all run in.
Dave
Dave
