when starting
djh66
Main scooter: 150 special
the lammy, cold, with choke on, it bursts into life first kick, but it burbles and if I open the throttle it dies. It will rev normally after 30 seconds. Any ideas? too big pilot?
cheers
Bring Me Sunshine COYH
bristolmod
Crystal balls a bit iffy at the moment I'm afraid........................
Engine spec; carb; jetting etc please.............
Scootering since 1968.
djh66
bristolmod wrote:Crystal balls a bit iffy at the moment I'm afraid........................
GT186 24MM PWK BREATHING THROUGH RAM, GJH NEEDLE (MIDDLE CLIP), 118 MAIN, K34 PILOT
Rich_T
Main scooter: Li Special
If it revs alright after 30 seconds it isn't the idle just it is most probably the choke jet size but either way what you are describing is completely normal for a cold start on a choke, even my NC30's do it.
As a word of advice for all Lambretta engines, I wouldn't advocate gunning any engine from a cold start until it had ticked over for a bit and at least got some warmth into it.
djh66
Other than that, RichT, the GT kit is running great, still got to get a few more miles on the clock to run it in, but I will mail you my final carb spec. when all run in.
Dave
Rich_T
many thanks, I'll keep a note and update the manuals with the information when it comes.
